Hey everyone, I'm getting ready to install my Aquamist HSF-6. I just want to run by everyone how I plan on running it. I also want to run the math by everyone. Ok here we go!!! By the way I'm using the information from the manual and from Howerton Engineering.
I'm running 950cc injectors, 50/50 Mix of Water and Meth, and 26psi Peak boost 950 X 4 = 3800 50/50 calls for 20% of fuel flow 3800 X 0.2 = 760 add 10% system losses: 760 X 1.1 = 836cc The new pump runs 165psi, subtracting 26psi Peak Boost gives you 139psi ( I rounded up to 140 ). Can I do it that way or does it have to be exact? So with that amount of required injection I'll need to run a dual nozzle set up. Looking at the chart provided I'll need to use a 1mm ( 548cc ) and 0.5 ( 284cc ) for a grand total of........ 832cc total injection. Not quite 836, so here is a question for everyone. Should I run as close to the required cc or should I run over that amount and limit it down some how?? Also I want to run the nozzles with the 1mm about 16-18inches from the TB and the 0.5mm at 12 inches or so. Ok I think thats all I got let me know what you think, and hopefully this all makes sense im not entirely sure it even makes sense to me! |
no help? I guess it works out good then.
The calculation is very good.
I suggest running a bigger jert overall so that you have sorr headroom. Since you have a progressive system, you don't need to limit your ceiling.
Sounds good, I think I'll end up running a 1mm and a 0.8mm to see where I'm at, I'm hoping I can trim it down if I need to. Thanks for the info Richard! Now I'm off to the next problem..... Since I just have a MBC and not I'm not using the EBCS, I'm a little confused as to how I would get everything to work together. I'm running 21psi on the pump gas tune and want to run 26psi on the Meth injection. I do not have a MAC valve or any other 3 port BCS. Do I need to have one of these in order to make it work together??
