Old 23-12-2011, 04:19 PM
mindblower mindblower is offline
Default Re: Aquamist HFS-3 system for 2010 ..... "Q and A"
huge thanks for info!
jumper has been added to inject by map sensor 0-5v by fords own sensor.
Old 06-12-2012, 07:59 AM
KushZen KushZen is offline
Pardon my ignorance if this has been stated before, but I just bought a HFS-3 Kit for my Nissan 350z. My flash tune allows me to change maps on the fly, however I don't think it works with the Aquamist failsafe map switcher. In any case, Am I able to wire a manual On/Off Switch to the HFS-3 system so that I can use a map WITH meth, and a map for daily driving WITHOUT meth to save methanol and gas mileage?
Old 06-12-2012, 04:56 PM
This can be done automatically by using the white and brown wire from the grey connector. (provided it is not used for something else already).
When you switch the system off at the dash gauge, the brown and white wire will go open circuit.
What type of signal is required for the flash to change map? A voltage or make/break contact to ground?
Old 12-12-2012, 09:36 AM
So basically, if I wire nothing to the white and brown wires, I can switch the Aquamist system off?
I'm not sure what kind of electrical signal is needed. The way we change maps is by holding down the cruise control set button while pressing cruise control cancel an X amount of times for the map we want to switch to.
Old 12-12-2012, 04:27 PM
Howerton Engineering
You just use the button on the face of the gauge to turn the Aquamist on/off.
Old 12-12-2012, 10:39 PM
Well.. I feel like a complete idiot now. Thanks for the info guys!
Old 17-04-2013, 07:51 PM
Aviator_2004 Aviator_2004 is offline
Hello Richard, I live in Belarus. I have a problem. help me to solve it, please. was purchased and installed Aquamis thfs-3 , confused RG 48 connector from fuel injector with connector RG 48 ECU . now nothing works. .dash gauge is off, the controller ECU is off. just click only time something(relay ecu?) once, when the power is turned.... please, may be necessary to make a diagnosis, how?
Old 17-04-2013, 11:42 PM
Does the gauge light up?
Old 19-04-2013, 11:03 PM
no, Richard
Old 19-04-2013, 11:58 PM
I think the controller is no longer functioning due to mis-wiring so a repair is necessary. Please send the controller and gauge n-back to us. If it is repairable, it will not be charged since it is a relatively new system.
I will wait for it.
