Old 17-01-2017, 07:06 PM
Nicknacke36 Nicknacke36 is offline
Default Re: Aquamist 3 issues
😊 Hoping to get it fixed soon, be nice to have it running properly...
Old 20-01-2017, 08:26 PM
This system was made in March 2013. It should work with your BMW without and problem. It is a version 2.
Please tell me some brief history of the system.
Old 21-01-2017, 09:15 PM
It was previously fitted on a turbo focus, when it was removed it had all cables cut (fav, water level and flow meter) All of which I've rejoined.. the guage lead was intact. The system has been primed and I've tested the guage by moving the jumper and it lit up okay...
Old 22-01-2017, 08:53 AM
When you performed the SYS test, did the gauge showed any flow bars?
Old 22-01-2017, 08:34 PM
Yea, and when I adjusted the screw I could fill the guage with more bars
Old 27-01-2017, 04:01 PM
I'm going to try testing the water level sensor today just incase...
Old 27-01-2017, 11:57 PM
On the previous Focus installation, did you get any relay clicks?
I think the issue is your injector circuit and power circuit. I don't it is a HFS3 issue.
Can you check your fuel injectors have resistor pack?
To check this, just remove the thin red wire of the grey harness and connect it to a known steady 12V supply. If the click gores away. The issue is caused by the resistor pack.
A pulsed 12V supply will cause the relay to click. Does this make sense?
Old 28-01-2017, 04:07 PM
The relay constantly clicks definitely. That sounds like the isssue.. I'll give it a crack and get back to you
Old 29-01-2017, 06:35 AM
I don't think you have taken in what I was trying to tell you. An unstable 12V from the red wire of the grey harness will cause the relay to click. It is a wiring issue, nothing to do with the HFS3.
Old 30-01-2017, 07:51 PM
So sorry would I need to move the red lead to somewhere else if it is pulsed? Sorry for not being a bit more clued up with this :/ I've just wired it up according to the wiring diagram..
Tags
aquamist, hfs-3 issues, no bars, water level sensor
