Old 28-04-2012, 08:27 AM
Default Re: Mazdaspeed 6 (update) SN #12091 onwards
You can certainly run HFS-2 on your car, injection is based on IDC only or 70% IDC/30% manifold pressure.
You need a 1/8NPT tap and a few drop of loctite for the nozzle adaptor.
Old 29-04-2012, 01:36 AM
silversport silversport is offline
OK,
What will be the best way to order; if I can get a link for best results.
Thanks,
Old 29-04-2012, 08:52 AM
Please check your pm.
Old 13-05-2012, 12:31 PM
Yes, you can. Make sure it is a HFS2-v2. Ity can be upgraded later.
Old 13-05-2012, 12:33 PM
The v2 wiring diagram has been updated to v3.
13th May 2012
Old 08-07-2012, 03:50 PM
The v3 wiring diagram has been updated to v4.
8th July 2012
Old 30-05-2013, 08:43 PM
Presss Presss is offline
Default Re: Mazdaspeed 6 (update: 8th July 2012 ) SN #12091 onwards
Hi Richard,
I recently bought HFS4. Electric men installed me as WIRING DIAGRAM MS6 v4. And then my boost stay lower than it was. And I understood that my boost control brains of HFS4. Set jets which was included 0.7 mm.
when we are working on 100% IDC + gain MAX then red LED turns around 4000 rpm. and the boost is reduced to 0.8 bar
it means that jets too small for my configuration.
but when I turn on the 100% boost then red LED does not light up. But still, my car is going slower than before the installation HFS4. HFS4 brains cut off boost by themselves .
WHY???
tell me which way to IDC, or boost? I bought this WMI HFS due just this working by IDC.
power of the car before installation was 320 hp now its about 270-300hp.
my modes:
FMIC, CAI, full exhaust 3'' + versatuner
I plan to get 350 hp
thanks
Old 30-05-2013, 08:50 PM
What water/methanol mix are you running?
Old 03-06-2013, 10:41 AM
water meth 50/50
Old 09-06-2013, 01:21 PM
Hi Richard do you remember my questions?
please... i need your help
