Old 11-06-2018, 09:38 PM
Default Re: Water Level light
This is good news. I like you to examine the wiring underneath the relay as well as the relay contacts.
Old 13-06-2018, 02:06 AM
tezlum tezlum is offline
I got the pump all reassembled and purged the lines pre fav then purged the jets with a normal spray pattern. But I noticed the water light stayed on when the sys jumper was on and with or without the fav jumper. The light turns off when the system is not injecting but on as soon as it stops injecting it waits for the failsafe reset then goes off
Old 13-06-2018, 03:55 PM
I noticed now when hitting bumps or turning quickly without the thereshold being activated I occasionally get the water level light blink or stay on for a moment
Old 25-06-2018, 03:58 PM
I have tried testing all the contacts and wires for shorts and switching relays and fuses but still every time it injects even when in sys mode with the jets out still activates the water level light only and failsafe activated
Old 25-06-2018, 09:21 PM
lets go back a bit.
What is the serial number of the controller?
I don't recognise this part what is it?
Old 25-06-2018, 09:39 PM
more questions:
1. What car is it?
2. What is the HP
3. What is the size of your fuel injector
Old 25-06-2018, 09:40 PM
lets go back a bit.
That part is the relay plug for the pump harness with die electric grese but that has been cleaned off now as I thought it might be an issue. I believe the controller is the v3.0
Old 25-06-2018, 09:42 PM
more questions:
1. What car is it?
2. What is the HP
2009 WRX
300 Wheel HP
1000cc/min
I do have the gain at -25% and 1.5x scaler soldered on the back and 1.0 link cut
Old 25-06-2018, 09:47 PM
The system was made in August 2014, you waited 4 years to have it installed?
It is strange, you have done all the right things.
Old 25-06-2018, 09:52 PM
I think the problem is caused by mis-matching of the HP vs injector size.
I had bought it "new" last year from someone that had never installed or unpackaged anything from the kit. Would you recomend going to a single jet?
