Old 26-06-2018, 10:16 PM
Default Re: Water Level light
Do make a video. I am totally confused from your descriptions.
Old 27-06-2018, 12:44 AM
tezlum tezlum is offline
Made a video of the issue and when the water level light comes on by its self the failsafe is on it does this with or without the level sensor plugged in
https://youtu.be/RvxhNH0ZoiY
Old 27-06-2018, 10:10 AM
I can see there is a short delay between the switching of the two leds, it is normal. It processes the failsafe differently.
Send a picture of the trimmers on the controller, The FSDL trimmer will affect the delay time.
Old 27-06-2018, 10:15 AM
Have you solder linked the x1.5 IDC scaler? Your injectors are way to large for your power.
Old 27-06-2018, 02:59 PM
The 1.5 scale is soldered and 1.0 it cut
Old 27-06-2018, 05:40 PM
Thres 10 o'clock
Gain max ccw 7 o'clock
F's-dl 12 o'clock
Dim 1 o'clock
Old 14-08-2019, 02:06 AM
Dans42.7 Dans42.7 is offline
I am having this exact issue was a fix found for this?
Hfs-3.1
Old 14-08-2019, 11:54 AM
what is the serial number of your system and where is the water pump installed?
Old 14-08-2019, 09:16 PM
The pump is mounted in the trunk.
I was able to adjust my WH on the gauge two clicks clockwise and this seems to have fixed my issue. I must have been just hitting the fail safe I was only getting the low level light illuminated though.
I will monitor it the next couple of days.
Thanks for the quick reply.
Old 15-08-2019, 06:21 AM
The flow sensor has detect a change in one of the foloowng:
1. fluid viscosity change due to lower temperatures
2. build up of debris in the jet (partial clog)
3. Water/meth ratio change
