Old 16-07-2015, 04:37 PM
VegasChef VegasChef is offline
Default Re: Mazdaspeed 6 (update: 8th July 2012 ) SN #12091 onwards
Hi @Richard L;
I Just purchased an aqumist kit for my MS6 and its beautiful so far. I do have a few questions/concerns. Would you be able to update the drawing to include the "user" port wiring. I noticed that it has it for the MS3 but not the MS6. Also the underside of the board is a bit different than the one you have posted. I have the v3.1 so im not sure if this has changed atall. I followed the book as far as setting the Jumpers for a DI motor.
Old 17-07-2015, 07:33 PM
I will work on this this weekend, Wiring will remain the same.
You need the x2.5 jumper configuration.
Old 23-07-2015, 05:39 PM
Hi Richard,
Any updates on wiring? Also had a question about soldering jumpers. Im going to be running 28-30+ PSI do i need to cut/solder (6)
Old 01-08-2015, 06:44 PM
Update is up, sorry for the delay.
The V3.1 is configured for a 3.5 bar MAP sensor from factory. So no mods.
Old 14-08-2015, 05:59 AM
Default Re: Mazdaspeed 6 (update: 1st August 2015 ) SN #12751 on onwards
Hi Richard,
Got everything installed and went to test the system today. Ran into and issue where when I first plug in the trunk the gauge will stay on for 10 seconds or less then I can hear a click inside I'd the controller and then the gauge shuts off.
Any ideas? Thank.
Old 14-08-2015, 07:13 AM
looks like the one of the following:
- tank sensor is installed upside down,
- no water in the tank
Old 02-06-2017, 08:19 AM
kevin_mps kevin_mps is offline
Hi richard.
are you able to get an ecu diagram up for the speed 6 like you have the speed 3?
Old 02-06-2017, 06:22 PM
The OE ECU only rr wiring diagram for HFS4+ECU?
