Old 06-03-2005, 02:35 PM
I have just received 5 litre of pure Nitromethane form G-max.
Here is a couple of pictures of it.
Old 08-03-2005, 04:26 PM
janis janis is offline
Did you manage to try the stuff yet?
Old 08-03-2005, 11:32 PM
First of all, I need to find a way to dissolve the stuff in water.
And then do some long term compatibility test with our pump seals. Teflon is the seal I will try first.
I don't have a turbo car, I will try it on my daily driver - Citroen Picasso.
Old 09-03-2005, 09:48 AM
doctorfrag doctorfrag is offline
Default Nitromethane
I am planning on making up a 50/40/10 methanol/water/Nitromethane mix, the nitromethane can dissolve in the methanol, reading here it seems that up to 10% by volume can be used with out having to worry about a/f ratios.
This will be some time early summer, as I don't have the money for a separate remap for this, but I will map with 50/50 Methanol/water first of all on the rollers, then put in the above mix and then run her again. I am concerned that it may affect detonation which is why I want to do it this way,.. to be safe!
If there are noticeable gains, then I will try stronger concentrations
Joe
Old 09-03-2005, 07:01 PM
JohnA JohnA is offline
Judging from this label, nitromethane sure looks like the Devil's brew :lol:
I wonder if it reacts with plastics, aluminium, brass fittings, etc. Nasty piece of work it is... :shock:
Cheers,
John
www.max-boost.co.uk
Old 10-03-2005, 08:58 PM
Had a bit of time today to play...
First I put a few drop on a metal plinth, hit lightly with a hammer, nothing much happen. Hitting harder and hard, just can't ignite it.
The next test: put a few drop under a 40-ton fly-press. Again failed to make it ignite when struck.
Mixed 33/33/33 M/W/N but the couldn't dissolve all the nitro, see picture below:
I then put two drops of washing up liquid, shoke it a bit, went milky within a few seconds-appeared to have emulsified. Left it overnight, Shall have the answer tomorrow.
Old 10-03-2005, 10:09 PM
Washing up liquid eh?
Fairy any good?
If this keeps it suspended, I'd be tempted to try it myself.
But it will need a special tank I suppose, can't use the windscreen wiper bottle eh?
Cheers,
John
www.max-boost.co.uk
Old 11-03-2005, 02:31 AM
chucktoo chucktoo is offline
Default Lab
Thanks Richard for the lab class.
It would be interesting to see if the 50-40-10 mixture Water-Methanol-Nitro mix actualy works and does not seperate out.
Old 11-03-2005, 10:28 PM
The solution has separated but appeared less nitromethane was left at the bottom - washing up liquid seemed to have made the nitromethane more soluable in water/methanol.
Old 11-03-2005, 11:12 PM
Default Re: Lab
I will try that mix next for you and will post a picture.
