#61
Re: Help please,HFS 4 V3 wiring diagram for E63 AMG
By the way we use one jet , could you describe me how to modify the circuit for one jet ?
#62
Good, That is all you need to d on the grey wire.
#63
What size?
#64
#65
You don't need to make any circuit change with that.
#66
Thanks for the support. we cut the thin wire between at C , And also we change the position of a jumper ; The system is okay , now |
#67
According to our record, your system was shipped to someone in Bulgaria. It was April last year, It took almost a year. Some solder configurations were incorrect, it was not done At aquamist. You friend was not telling the truth. It could not be brand new.
You have one more solder mods. The MPS "2" link has to either be cut or unsolder "3".
#68
#69
OK, so far so good.
Lets look into the IDC trigger problem. I like to take some voltage reading on test pin #16 at: 1. pre-crank 2. idling 3. quick flip of the throttle.
#70
I will measure it on monday
