Old 07-06-2017, 03:44 AM
Gclasse Gclasse is offline
Default Pump Wiring Harness / Level Sensor 2 pin Connector
Hello, just found out that the level sensor 2 pin connector is missing from the used HSF4 kit i bought, can anyone point me where i can source the 2 pin connector that is currently on the kit?? otherwise i will repair with a standard connector it but will have to cut and change the level sensor cable end as well.
By the way, i'll be installing in a 996
Old 07-06-2017, 05:44 PM
Default Re: Pump Wiring Harness / Level Sensor 2 pin Connector
The connector is made by tyco or amp. You can use any pair of mating connectors for this
Old 08-06-2017, 04:48 AM
Hey Richard! thanks for the Info.. i ended up using a Molex Male / Female connector plus added a little bit more or cable. Continuity checked on all cables and everything in good shape now!
some pics
Old 08-06-2017, 08:03 AM
Thank for the update... All good.
Old 09-06-2017, 03:37 AM
Richard, can you tell me the dimensions of all the orings used in the system? Also the one that goes on the right angle fitting as well!
Old 10-06-2017, 08:07 AM
I don't know the size of the o-ring on the right-angle fitting as we don't make them.
There are many o-rings on the system , be a bit more specific.
Old 13-06-2017, 04:01 AM
Wink Re: Pump Wiring Harness / Level Sensor 2 pin Connector
Don't worry Richard, Jeff (Howerton engineering) sent me some spare orings on different sizes. All good now!
Old 13-06-2017, 04:09 AM
Default another question on my install
Richard, on my setup (porsche), i decided to install the nozzles at both intercoolers sides. Therefore, I placed the FAV close to driver side intercooler and from there I ran the 4mm tubing to a check valve which was then distributed to each intercooler. Refer to pictures included.
On your experience, Is there a concern with the total length of the 4mm used on this setup?
Old 13-06-2017, 07:03 AM
I suggest putting an inline checkvalve near the far-away jet to stop water siphoning after lift off.
Old 13-06-2017, 08:48 PM
Got it, ordered one from your website today! thanks
